ZB4 (PC) Saving a project .ZPR
Hi all.
when I will save a project on this way:
… Saving a Project is similar as saving a Tool or any other kind of element:
• Go to the File palette and click on the Save As button a system window will appear.
• Choose the destination folder and enter a name.
• Click on the system window’s Save button.
then in my opinion
I can have either an .ZPR or save an .ZTL
but there is no option for .ZPR only for .ZTL
Thank you for your help
What version of ZBrush are you using? Zbrush 4 has a new palette called ‘File’. You save a project from the top of that.
Hi Macus :slight_smile:
ZB4, I’m blind, I’ve overlooked :wink:
thanks, for the quick reply
Problem solved I found it.
Thank you very much
the new file format is really cool!
thankyou guys!
Hahah, I just scared myself with this, decided to save with the tab up top and came back to it this morning, wtf is a .ZPR! Couldn’t load tool like usual. Nooo itss all gonne, ZB ate it, should of saved in iterations! Thanks for clearing that up. Back where I left off.
