- resolved *
same here, what was the solution ???
Thanks,
-Ronald
i can’t seem to remember. that was a good while back, sorry Ronald.
Wow, i just found the email support ticket in my inbox - see below:
Hi Tim,
Thank you for using ZBrush!
What I would like you to do is to perform what is called a Clean Installation. This is not a regular uninstall and reinstall type situation. It involves removing some files after uninstalling.
Follow theses steps to perform a clean installation and get ZBrush activated:
- Uninstall ALL releases of ZBrush from your computer.
- Locate and delete the Pixologic folder that is left behind. This is will be in your Program Files (x86) directory.
- Locate and delete the \Users\Public\Documents\ZBrushData folder.
- Locate and delete the \Users\Public\Pixologic folder.
- Make sure you are now logged into the computer as a full admin user.
- Disable any anti-virus software running IMPORTANT STEP Anti-virus software causes 90% of all problems with file corruptions when installing ZBrush.
- Use the full installer to install ZBrush 4R7 P3. (I have had your email with your download link resent to you)
- Start up ZBrush and choose the Web Activation method to get your activation code.
- Once you have ZBrush activated it is safe to turn your anti-virus software back on.
Sincerely,
Will Miller
Pixologic Support
