ZApplink with Corel Painter
Hi everyone, I am new to ZBrushCentral, so I hope this is the right forum. Feel free to delete/move my post if it is not,.
Today I played around with the ZApplink feature of ZBrush and while it wirked fine with most of my image editing applications (Gimp, ClipStudioPaint, Krita, Artrage) I had no luck using it with Corel Painter 12 (which is the application I actually wanted to use). When I click “drop now”, ZBrush opens Painter but I get the error message that “Unsupported effects or adjustment layers have been detected”. I can then open the file without effects and while all the layers seem to have imported fine, the names of the respective layers are wrong (The base layer is called “Canvas”, the other two layers are both named “Fill ZShading (do not edit)”). When I then edit the image in Painter, ZBrush of course does not recognuze the format and the reimport does not work. It seems that it works when I manually rename the layers and set the layer modes (although ZBrush automatically opens Projection master in order to do so?) , but having to do this every time kind of defeats the purpose of ZApplink as a one-click solution. Since I read multiple times that people are using Corel Painter with ZApplink, I wanted to ask if anyone knows a better solution.
I never could get it to work properly, Ryan Kingslien helped me by sending modified scripts to try, when he worked for pixologic, but it turned out to be a useless exercise, I gave up in the end.
