zapplink doesn't work when editing in photoshop use the 'pen tool'
Hi all!
I just got some problems when use the Zapplink.
Everything is good, only if use the pen tool in photoshop!
I saved the document,and I’m sure the middle layer named ‘layer 1’,and I go back to Zbrush,but it doesn’t show the ‘Re Enter Zbrush’ dialogbox.
Just tried a number of times,every time didn’t show the ‘Re Enter Zbrush’ dialogbox,and when use some other tools in photoshop like the brush tool or marquee tool,everything is fine. How could this happen?
Plus,this is the first time I use zplug,and use zbrush 4 and PS CS5.
Same things are happening to me. I’m not able to consistently get the reeneter ZBrush. Some changes I make in Photoshop will work(not sure which ones) and others will not.
Can’t really use it like this.
It has aways been the case that there are times Zapplink doesn’t seem to recognize that you have edited the mesh and saved it in Photoshop. The screen in Zbrush doesn’t indicate a change had been made. The solution has aways been to return to Photoshop and “ctl+s” to save again and then when you return to zbrush the edit is recognized. I’m not sure if this is what you are referring to.
I noticed there is now a “re-check” button when you re-enter Zbrush for just this occasion. I was able to duplicate what I described above and the recheck button worked perfectly.
I hope this helps. I’m otherwise unclear on what your problem might be. I think its coincidental that the process went smoother while you used the pen tool. I doubt you are having a problem specific to one photoshop tool.
Please post questions and issues to do with ZAppLink in this thread:
http://www.zbrushcentral.com/showthread.php?t=95890
Thank you.
I tried to save the psd again,but unfortunately no work. :frowning:
