ZAppLink doesn't apply texture to model [Solved]
Hi, I am using Zapplink on ZBrush 4R7 x64 Mac. I am on a particular subtool, do the Zapplink stuff to edit a texture in Photoshop then pick-up back into ZBrush. All that is fine. BUT after the pick up, when I rotate the view of my subtool in Zbrush, my texture is not applied to the subtool, the texture is just hanging in front of the screen, not moving at all with the subtool. How come?
Edit: ok I have found the problem, when I was merging down in Photoshop I was not preserving the mask, this apparently caused problem…
OK, glad you solved the problem. Thanks for letting us know.
