Are there any ways to make work ZApplink with objects without uvs’ ?
yes. document.zapplink. make sure colorize is turned on.
beta_channel, not working. With polypainting i turn onn colorize.
Everything ok until the last stage. When i back, from Photohsop to Zbrush, in Zbrush
i see my paintings, but after i press Accept - all changes, that i made in Photoshop, will be deleted.
What’s wrong?
Do you have any 3d layers? Polypaint with layers is weird. It will only apply the changes to previously painted areas.
Nyx702, ok, i’ll ckeck it at work.
Ye, thx guys. It works now, after baking layers.
side note - you CANNOT be using Flat Color when using Zapplink. My guess is that’s your problem. You can turn off the shading layer inside of photoshop if you want to see your flats. Just remember to turn it back on before saving and heading back to Zbrush.
My guess is that’s killing you.
beta_channel no man. I knew this.
Trouble was in 3D layers. I forgot about them.
Thanks anyway.
