i have the latest Z brush when i go to plug ins so i can send it to
PHOTOSHOP
it does not accept it but in the past it did .I did whatever it requires in the message still it doesn’t, could it be PHOTOSHOP it self does not allow it anymore
Hello @luca7818 ,
In the event you’re talking about GoZ for ZBrush, Adobe has been phasing out support for 3D in Photoshop for the last few versions. It is not expected to work and is only around for people using much older versions of Photoshop.
If you’re referring to the ZBrush to Photoshop plugin, I don’t immediately have any problems sending from ZBrush 2023.0.1. It is expected that there will be a pop up warning asking yo to confirm that you wish to run the script. This is coming from Photoshop itself, and to suppress the warning you would need to follow the directions in the message.
Please contact Maxon Support for any technical issues with ZBrush and be prepared to document the problem.
Thank you!
