Z Modeler Dropdown menu
My Z Modeler Brush dropdown menu when pressing shift key is cutoff at the top of the screen how do I reposition it so that all the options are visible?
Your display resolution is probably lower than the minimum requirement for ZBrush.
Can I move down the menu so its centered in the screen? Ive tried everything Ive found in the documentation and google search.
No. If your display resolution is less than the minimum requirement there is nothing you can do. That’s why it’s a minimum requirement rather than a recommended specification. :wink:
