Hi when i start zbrush i can with a reasonable pressure make a visible brush stroke in the clay but every stoke needs to ba a little bit harder to sustain the same z intensity here a example of a sphere where i make 100 stroke with same pressure… this happens only with zbrush. i use a wacom intuos latest model. the pressure indicator in the wacom app show allways the same/correct pressure, so its zbrush that interpretes the pressure weaker and waker after time.
Hello @donald_rattler ,
ZBrush doesn’t have any capacity to decrease your pressure sensitivity over time. It only uses the input it is given.
Licensed users of ZBrush should contact ZBrush support for technical issues with their ZBrush installation. We can’t conduct technical support over the community forums and otherr users on the Usage Questions forums wont be able to help you with system specific technical issues.
Thank you!
