Hi all,
Ronald here,
I’m starting to build a RandomFace Generator and Facial Animating script for ZBrush,
I have all the folders sorted,like in FaceGen Here is the link : http://facegen.com/
it’s free of use,
I use it for my template and copying facial expressions, in the free version you can’t export though,
But thats no problem it is great for facial animation copying.
But I want to make a plugging for ZBrush or Zscript,but I have a couple of questions:
I’m just starting scripting,only been doing some simple macro stuff,
But this requires some heavy scripting…
Ok here goes:
I need the option to get all layer names,a option to change all layers to different parameters for the random face
And a way to have some layers do more morphing than the others perhaps,
I need a scripting way to change layers with script,
Also a converting way to compile a 3D layer and intensity slider setting,to a percentage var and unique ID
Im a terrible scripter I hope you can make sence of what im talking about.
Is this possible trough scripting?
When the morphing part is done im going for the polycolor layer stuff.
Some help will be greatly appreciated!
ps here is some small macro I just made for Silhouetting,I find it very usefull:
Silhouetting On:
//ZBRUSH MACRO - Recorded in ZBrush version 4.42
[IButton,???,“Press to run this macro. Macros can be aborted by pressing the ëescí key.”,
[IShowActions,0]
[IConfig,4.42]
[IColorSet,149,149,149]
[ISet,Document:Back,149.5843]
[ISet,Document:Range,0.85714]
[IColorSet,0,0,0]
[IPress,Material:Flat Color]
[IColorSet,10,10,10]
[IPress,Color:FillObject]
[IPress,Brush:Move]
Silhouetting OFF:
[IShowActions,0]
[IConfig,4.42]
[IPress,Material:BasicMaterial2]
[IColorSet,255,255,255]
[IColorSet,53,53,53]
[ISet,Document:Back,53.20784]
[ISet,Document:Range,0.4]
[IPress,Brush:ClayTubes]
[IPress,Alpha:~BrushAlpha]
[IPress,Alpha:Alpha 01]
Just Turn on record macro ,and click once in canvas , end macroscript,Use the ‘‘Silhouetting On’’ name,and put it in Zstartup/Macros or make a folder in there, then use the code ,to copy paste over the .txt
The same goes for the second code,just use “Silhouetting Off” for the name.
btw is there a way to change macro names?
I tried to rename in the folder and do a reload but the new names don’t show up…
BFN
Best Regards,
Ronald
