Z-Depth maps
Guys I’ve just started using Vue 4 Pro a the final render can produce a Z- Depth map…can ZB2 use this map for 2.5 D work along side the finished render or am I asking to much.
If it can be done, any chance you can tell me how…:smiley:
Cheers
Go to your alpha pallette and select the “Import” button and load in your Z-Depth map. You can then click on the button labelled “Fill Doc” in your alpha-pallette.
So ZB2 will be able to use the Z- Depth info…:sunglasses:
This app just gets better & better:+1:
