Can someone clearly explain to me how to export your Zbrush images without that gradient background?
Found one! Nevermind…
One option is to turn off the gradient itself. You can do this under Document: Range.
Drop it down to 0 and there’s no more gradient. You can also set a new background color here.
Another option is to use BPR to render out your passes. Once you use BPR at least once, you can access each individual pass under Render: BPR RenderPass. You can left click each pass to export them out as PSDs. This includes a nice mask pass which can be used for compositing the images in photoshop or a similar program.
Sounds good, Thank you!
