@stonecutter:
>>>>"… in my head!"<<<<<<
camera {location <20,40,28> direction 2*z look_at <0,2,0>}
light_source {<-140,200,300> rgb <1.0, 1.0, 0.95>*1.5}
light_source {<140,200,-300> rgb <0.9, 0.9, 1.00>*0.8 shadowless}
#declare r1 = seed(0);
//----------------------- THE TABLE
#declare Pig_1 =
pigment {
gradient z
color_map {
[0.00, rgb <0.01, 0.59, 0.81>]
[0.70, rgb <0.01, 0.59, 0.81>]
[0.70, rgb <0.98, 0.98, 0.87>]
[1.00, rgb <0.98, 0.98, 0.87>]
frequency 4
#declare Pig_2 =
pigment {
bozo
color_map {
[0.00, rgb <0.35, 0.58, 0.88>*1.0]
[0.25, rgb <0.35, 0.58, 0.88>*1.1]
[0.50, rgb <0.35, 0.58, 0.88>*0.9]
[0.75, rgb <0.35, 0.58, 0.88>*1.0]
[1.00, rgb <0.35, 0.58, 0.88>*0.8]
scale 0.1
#declare Nappe =
cylinder {0,y*-1,50
texture {
pigment {
gradient x
pigment_map {
[0.0, Pig_1]
[0.5, Pig_1]
[0.5, Pig_2]
[1.0, Pig_2]
warp {turbulence .05 octaves 2}
normal {quilted 0.6 scale 0.025 warp {turbulence 0.05 octaves 2}}
scale 5
translate 10
object {Nappe}
//----------------------- BISCUITS
#declare Tex_Biscuit =
texture {
pigment {color rgb <0.98, 0.83, 0.58>}
normal {dents 1.2 scale 0.01}
finish {phong 0 brilliance 0.7}
#declare Base_Biscuit =
union {
blob {
threshold 0.7
#declare I = 0;
#while (I < 359)
sphere {<4,0,0>, 1+rand(r1)0.1, 1 rotate yI}
#declare I = I+(360/28);
#end
cylinder {<0,0,0>, <0,0.5,0>, 4}
texture {Tex_Biscuit}
#declare Chocolate =
union {
difference {
cone {<0,0,0>, 4.2, <0,0.4,0>, 4}
cone {<0,0.1,0>, 3.6, <0,0.401,0>, 3.75}
torus {
3.55, 0.1
translate y0.2
clipped_by {torus {3.55+0.1, 0.1 translate y0.1}}
union {
#declare I = -4;
#while (I < 4)
cylinder {<-4,0.1,I>,<4,0.1,I>, 0.05}
#declare I = I+0.5;
#end
clipped_by {cone {<0,0,0>, 4.2, <0,0.4,0>, 4}}
torus {3.96, 0.04 translate y0.4}
torus {3.79, 0.04 translate y0.4}
#declare LogoFun =
object{Povray_Logo_Prism rotate x90 scale 2.2 translate -0.3z}
#declare ProjLogo =
blob {
threshold 0.6
#declare I = 0;
#while (I < 1)
#declare Pos = <-2+rand(r1)*4, 0, -2+rand(r1)*4>;
#if (inside(LogoFun,Pos))
sphere {Pos, 0.08, 1}
#end
#declare I = I+0.0002;
#end
#declare Black_Chocolate =
texture {
pigment {color rgb <0.24, 0.10, 0.03>}
normal {wrinkles 0.2}
finish {specular 0.3}
#declare Milk_Chocolate =
texture {
pigment {color rgb <0.48, 0.26, 0.13>}
finish {specular 0.2}
#declare White_Chocolate =
texture {
pigment {color rgb <0.96, 0.95, 0.75>}
finish {ambient 0.3 specular 0.01}
#declare Icing = texture {
pigment {rgbf <0.95, 0.95, 1.00, 0.1>*1.2}
normal {bumps 0.1}
#declare Biscuit_1 =
union {
object {Base_Biscuit}
object {Chocolate translate y0.5 texture {Black_Chocolate}}
disc {
<0,0.101,0>, y, 3.6
translate y0.5
texture {Black_Chocolate} normal {bumps 0.3 scale 0.05}
object {ProjLogo scale 1.5 rotate y*-90 translate <-0.4,0.6,0.5> texture {Icing}}
translate y0.5
#declare Biscuit_2 =
union {
object {Chocolate translate y0.5 texture {Milk_Chocolate}}
disc {
<0,0.101,0>, y, 3.6
translate y0.5
texture {Milk_Chocolate} normal {bumps 0.3 scale 0.05}
object {ProjLogo scale 1.5 rotate y-90 translate <-0.4,0.6,0.5> texture {White_Chocolate}}
translate y0.5
#declare Biscuit_3 =
union {
object {Chocolate translate y0.5 texture {White_Chocolate}}
disc {
<0,0.101,0>, y, 3.6
translate y0.5
texture {White_Chocolate} normal {bumps 0.3 scale 0.05}
object {ProjLogo scale 1.5 rotate y-90 translate <-0.4,0.6,0.5> texture {Milk_Chocolate}}
translate y*0.5
object {Biscuit_2 rotate y*-80 translate <-3.5,0,2>}
object {Biscuit_1 rotate y*-120 translate <3.5,0,-4>}
object {Biscuit_3 rotate x*-4 translate <8.5,0.9,0>}
#macro SevenBiscuits (Bisc,Num)
union {
#declare I = 0;
#while (I < Num)
object {Bisc translate x9 rotate y60*I}
#declare I = I+1;
#end
object {Bisc}
#end
//----------------------- CRUMBS
#declare Fun_Sphere = function {xx + yy +z*z}
#declare Crumb =
isosurface {
function {Fun_Sphere(x,y,z) + f_noise3d(x2,y2,z*2)*1}
threshold 1
max_gradient 3.9
//max_gradient 15
accuracy 0.01
contained_by {box {-1,1}}
scale 0.5
#declare I = 0;
#while (I < 1)
object {
Crumb
rotate rand(r1)*360
scale 0.2+rand(r1)*0.3
translate <rand(r1)*10,0,rand(r1)*10>
object {
Crumb
rotate rand(r1)*360
scale 0.1+rand(r1)*0.15
#declare I = I+0.03;
#end
//----------------------- METAL BOX
#declare Pig3 =
pigment {
gradient y
color_map {
[0, rgb <0.1, 0.5, 0.7>]
[1, rgb <0.7, 0.6, 0.4>]
scale 0.5
#declare Pig4 =
pigment {
crackle
color_map {
[0, rgb <1.0, 0.5, 0.6>]
[1, rgb <0.0, 0.0, 0.0>]
scale 0.2
#declare MetalBoxPig =
pigment {
radial frequency 60
pigment_map {
[0.0, Pig3]
[0.5, Pig3]
[0.5, Pig4]
[1.0, Pig4]
#declare BiscuitBox =
union {
difference {
cylinder {<0,0,0>, <0,5,0>, 14}
cylinder {<0,0.1,0>, <0,5.1,0>, 13.9}
torus {14, 0.1 translate y5}
torus {14, 0.1 translate y0.1}
torus {14, 0.1 scale <1,2,1> translate y*4}
cylinder {
<0,0.3,0>,<0,3.5,0>, 14.01 open
pigment {MetalBoxPig}
finish {phong 0.8 reflection {0.01, 0.15}}
pigment {Gray60}
finish {phong 0.8 metallic reflection {0.5, 0.7}}
union {
object {BiscuitBox}
object {SevenBiscuits (Biscuit_1,6)}
object {SevenBiscuits (Biscuit_3,6) rotate y30 translate y1}
object {SevenBiscuits (Biscuit_2,5) rotate y0 translate y2}
rotate y*-75 translate <-18,0,-12>
//-----------------------CUP OF TEA
#declare TeaCup =
union {
difference {
cylinder {<0,1.2,0>, <0,6,0>, 4.2}
cylinder {<0,1,0>, <0,6.2,0>, 3.8}
you did, really!?
