Hi all,
It appears the XYZ-res of a Zsphere can only be set before it is created and cannot be changed afterward… is this true? Hope not… please tell how!
thanks!
-Joe
Hi all,
thanks!
-Joe
You can get automatic setting of the XYZ resolutions by using Tool : Adaptive Skin : Ires. That way your zsphere tool will adjust to changes easily.
But for the times when you want to define XYZres yourself you need to set it before you draw, or use a zscript.
Zif Widget Version 3.1, by Digits, or Zif Edit rev B allows you to change the XYZres post creation.
Both scripts have some issues in ZBrush 2, but should work.
Changing the resolution of the Root zsphere can only be done automatically (ires) or by using one of the zscripts.
Thanks, TVeyes
