Is there such a thing as an X,Y and Z compass? so when I rotate an object I can see which way it is?
Simple - X Y Z = R G B
If you bring up the gyro, it’s axes are color coded. Unpress Edit button and press Rotate button to see the gyro - observe colors, then repress Edit button.
Sven
- the Z is always pointing into the screen in Zbrush… and an X, is easy to check by pressing the X button for the symmetry
Thank you very much.
