So I’ve used the Xtractor brush successfully a few times in the past. However, I seem to be failing horrible right now.
I checked out the documentation and even followed the steps for how to use the brush.
Basic overview. - Open mesh, ctrl click undo history so it’s white, sculpt details, select Xtractor drag rec, go to alpha panel and click “from brush”, the brush now turns blue (as it’s supposed to), however when I got to drag it out on the newly sculped detail the blue circle disappears and won’t drag out like it used to (before you could rotate the horizontal line in the blue circle to orient it. The only “alpha” that is generated is a simple flat grey one.
I tried all the Xtractor brushes with the same result, any ideas?
Edit I’ve also tested this with the regular XTractor brush and when I go to drag it on the model to capture the alpha, the blue circle is sort of “stuck” in the top left corner of my canvas even though I was clicking on the detail in the middle of the screen.
This seem to be a 2021.7 issue as it worked fine in 2021.6.6 I believe
