Is anyone here running XSI under Vista 64bit? I ask because for me it runs once after install and then crashes if I shut it downa and try to run it again after that, it just crashes at startup.
I have just set up VMWare to run Windows XP Pro 32 bit in a window under Vista and it installs and runs fine on that, so I’m guessing it’s due to my Vista being 64 bit.
I really want it to work under Vista 64 because my 15 million poly ZBrush object loaded perfectly within XSI without using Displacement maps
