Xpose view issue
I’m trying to add xpose view to a movie on my latest model. The issue I’m having is that most, but not all subtools go back to their original start positions. A few tools get close but you can definitely tell they are hanging in mid air when moving the slider back to 0 :mad:. Any ideas why, or ways to fix?
Thanks
Instead of moving the slider back to zero, edit the Explode [XPose] track to place keyframes at the beginning and end of your movie with your model as it should be (all subtools in place), then move the Timeline cursor to the middle point, adjust the XPose slider to the maximum setting you want (e.g. 100) and place a third keyframe. ZBrush will automatically interpolate between the keyframes.
Thanks for your reply. Well, I tried using Xpose view even without the movie timeline and it was still acting the same way-certain subtools not returning to their original position. Tried using with and without the slider but both gave me the same result. Odd. So, since the subtools were easy parts to make-just bolt heads-I remade them, turned them into an insert brush, then split them into their own subtool. It works as it should now.
