Hi! I just got a Xencelabs tablet. Ive gone over all the settings for the tablet and in Zbrush but i cant get the pressure sensitivity to work with zbrush. Tweaking the sensitivity in the xencelabs app shows results in it but not in zbrush. Did the same for photoshop and it works fine, but cant figure out why its not working with zbrush… Any help with this would be great!
Check that Preferences:Tablet:Use Tablet is activated. Activate if not.
If that doesn’t work then try the three API options in Preferences:Tablet:Tablet API.
If after trying these options your tablet works then make the changes persistent with Preferences:Config:Store Config.
If none of this works then start a conversation with support.pixologic.com
Thanks! Got it to finally work
