This is a children’s folk tale story book, initial sculpt and texture to fur test render, to be posed later. If you like to play with it, here is the OBJ model:tiger-cub.zip
[attach=210801]WIP-Tiger-cub-2.jpg[/attach]
thank’s
The OBJ model has optimum mapping, hope you can turn it into lion or some other cats, here are some render tests, I don’t have time to make the eyes and it will be post process as require.
Continue working on monkey, polypaint color-fur density map, normal map and test render prior to comb the hair. I learn that all polygon parts must be left & right symmetry with center parting otherwise sub-divide will cause irregular center line.
An update of the transpose actions to wrap up the book.
nice animals and cool looking fur! :p
Very nice. Are you using Fiber material for the fur?
these are so cute. thnx for the model.
good luck on the book.
ron
I don’t know if the fur material is good enough for it, although I started from Zbrush 1.55, I never use the materials and the BPR is only introduced recently. Transpose sculpting is all I use other than texture paint.
The tiger cub was killed by the foolish man is the moral story, the white space is for text.
its really gr8 and so realistic. i like the model , texture everything. and the monkey is cool too.
you are a gr8 artist.
i really like to see your fur technique that how you achieve fur like this?
