Hello,
I am afraid that nobody so far has been able to help me with this problem. I posted it a month ago and I am reposting in hopes that somebody will know what to do.
I cannot export a base mesh of a multi s-div zbrush into Wings3D, save it out there, and import it back into ZBrush without having serious errors. The imported base mesh looks fine, but higher s-div levels are completely scrambled.
Here is what I do and what happens:
Export the lowest S-Div level of an S-div model (tool) created entirely in ZBrush. The lowest S-div has 1950 polygons (Pic 1). I exported with the settings in Pic 2.
In Wings 3D version 0.98.26 (latest stable version), import the model, and export it as an OBJ, without making a change.
With original tool (model) open to lowest S-div, import the new Wings 3D created OBJ file. Looks fine in S-div 1, but S-div 2 looks like Pic 3.
[](javascript:zb_insimg('10772','pic3.jpg',1,0)) Pic3 The result after re-importing the OBJ file created out of wings and increasing the S-div level to 2.
I have tried getting rid of polygroups so that groupings don’t mess it up, and that has failed also.
I beleive the vertex order is getting ruined, and ZBrush’s importer isn’t capable of fixing that (it should be able to, since the base meshes are the same. Just give the verticies the same order! how frustrating!)
Can anyone help?
Thanks
