When I want to lotate , and pentab at not subtool arerea, and move pentab …
Why the object(subtool) swing?
It is bad bewing for me to sculpt.
I want not swing small_orange_diamond
Where to change Setting ?
I’m not really sure to understand your problem. Can you reformulate?
Default behavior when you’re not over the model is to rotate. Get the Axis Plug and Middle Button plug. I posted some files for the UI that might be helpful to you.
I think the subtool is big (long) …
When I must wach Macro bewing and lotate, it (the long parts ) sometimes becomes big and little (swing) with rotate.
I often must sclupt at macro bewing .
If it can ,
when lotate the subtool, the subtool’s area which is out of display area behind … is no probrem.
I’m sorry if zbrush stting can’t change.
Is the plgin? file size big?
My PC c-drive alredy half section using …
And I have never inserted another ?plugin …
I think when it do , My PC explode …
sorry Clumsy English.
Takuto
The files altogether are small but helpful. You must stay with the wave
Takuto : do you have a way to record your screen to do a movie (Movie >> Record then Movie >> Export or by using a screen recording software) and showing the problem?
I think it will be more easier like this.
Just as a test, go in Tool >> Deformation and click Unify and test again.
I do not why ,but the problem was solved …:rolleyes:
…why? …
I did not do anything …
When I rotate the subtool ( long parts) with macro View,
I want sush a lotate Viewing …
sorry chabge bewing >>>>> view
Takuto
With Local button pressed, the model will rotate around the last clicked point. If your last clicked point is outside viewport, it will swing.
To reset the rotate point, I sometimes “touch” the model with smooth brush.
The right click navigation is also doing the rotation around the cursor position. Just press right click on the pen without touching the tablet surface.
 By the way ,
please watch image.
Although I have already question to pixologic …
C is DefoltDynaWax .
B is now sculpting figyure .
I heard Zbrush is Y up is - … .:o ?
and The top and bottom of now sclpting figure in the image is fliped in ZBrush ?
When I started sclupting this figure, well I do not know bug ? out, It seems subtools and X,Y,Z coordinates had been fliped.
I have Subtle Confusion in my head since the problem happened.
Although not particularly a big problem for me …
sorry basic question.
