Hi everyone
I’m trying to ZRemesh a dense imported obj and then reproject the diffuse map back onto the remeshed model but the resolution of the reprojected map is very poor.
This is my workflow:
- Import the original dense OBJ into ZBrush and run through Zremesher to bring the poly count down and improve the topology.
- Import the original object again and reapply its color map (so that I have something to project).
- Subdivide the remeshed version.
- Turn off Zadd and turn on Rgb. Append the tools and run Project All.
- Color map projects but is very low resolution.
You can see the different models and resultant low rez map in the attached images.
Can anyone give me some pointers as to where I’m going wrong?
