Dear Zbrushers,
I’ve a problem with 2,5D Alpha Brush. I select a Cube3D, edit, Makepolimesh 3D and orient it in oblique.Then ProjectionMaster, drop down with only Deformation and Normalized flagged on. I select 2,5D AlphaBrush, drag-rect stroke and an arrow shaped Alpha. When I drag-rect the Alpha on the Cube3D, the arrow does not orient itself like the below Cube 3D but it stays frontal to me (parallel to canvas). This even if PICKER is on CONT ORI. Why? I also notice that GYRO ROTATE does not work. Only GYRO MOVE and GYRO SCALE are possible. See attached picture. Why the 2,5D Alphabrush does not orient following CONT ORI mode? Is this normal? And what can I do if I want to drag-rect an Alpha in CONT ORI mode?
Thank you in advantage for your reply,
i wait for your suggestions,
best regards
Massimo
(Milan - Italy).
