So I have imported some hair polygon strips into zbrush and there are also corresponding color texture map and an opacity map. how can I import the opacity into zbrush and use it along with the color map?
Thanks
Thanks
Hello Zolly,
ZBrush doesn’t use Opacity maps. However, if you activate the Transparent texture option, ZBrush will read any 100% black area in the image as transparent.
