Ok, my question is, when I click rmb in area this rgb label appears. Always.
What is the problem?
When you right click by default it brings up a quick pop-up with a lot of useful, often-accessed functions, allowing you to do things like change color or brush stroke where you’re working, instead of drifting your hand to some other control elsewhere on the UI.
If it bothers you, it can be disabled in Preferences> Interface > Navigation > Enable RightClick Popup (disable then store configuration).
Thanks a lot for the help. I got it Spindel. Is a menu popup that always appears. Like to change colors right?!
But How can I zoom in Zbrush now?
ctrl + rmb is zoom right?
Fixed!
The zoom in zbrush still a mistery. Is difficult to use but I finally found.Thanks
In 3d edit mode you can either Ctrl +RMB to zoom, or Hold Alt + LMB, then release ALT while dragging with LMB to zoom. The latter function is designed to accommodate tablet users.
Be sure to update to the most recent version of Zbrush. It is free for registered users.
