What is best solution for GOZ between ZBRush 4R8 and Maya 2018?
Hi ZBrushers!
I am a bit confusing still. I just happened to use GOZ between ZBRush 4R8 and Maya 2018.
However, it does not work well.
After collecting some idea/tutorials/solutions from the web, it is maybe something to put necessary files into the necessary folder locations and rewrite some scripts.
But so far I may not find good solutions.
I think some ZBrushers already know how to solve this problem.
Can you share your ways?
M
2018-02-15
I am using R8 with Maya 2018 but it’s not that complicated, you just to Preferences >> GoZ and install it, that simple.
But I am facing another issue is everytime you press on GoZ a new Maya will open and it does not use the existing open Maya.
Sorry ZBrushers. It was my simple mistake not to check “path to maya”, at GOZ on Preference.
That way make ZBrush 4R8 and Maya 2018 connected.
But I am not sure or maybe you need to fix lost or not installed files into the folders, rewriting files?
Anyway ZBrush 4R8 GOZ problem is not like the one at 4R7, I am guessing.
