What defines the limitation for dynamesh resolution?
Big fan of dynamesh but I often find that combining multiple objects together decreases the resolution and that making objects longer in one or more axes does the same. I find dynamesh much faster than remeshing and projecting but often, I lose a large amount of detail due to this behaviour.
Is there a way to increase the resolution defined by the slider? I ask because I have read a good few threads that imply that scaling your model is the answer which doesn’t seem to be the case.
Thanks.
http://www.zbrushcentral.com/showthread.php?209418-Why-is-Zbrush-chugging-at-400k-total-points&p=1219766&viewfull=1#post1219766
Thanks, I suppose I’d like to know if there is a feature request service for Zbrush or if there is a way to unlock higher resolutions with a plugin or script?
