I have tried uninstalling and reinstalling. checking permissions. uninstalling other apps reinstalling OSX etc etc etc and still I cannot run zbrush 4r7. 4r6 and every other app runs fine.
If I had a clue as to what MIGHT be different between 4r6 and 4r7 as to what might be causing a conflict, I might then find out where the problem is.
By the way I am on osx 10.10.2
No idea if this is related
Jan 29 16:32:18 Mike-Rosss-iMac.local locationd[251]: Location icon should now be in state ‘Active’
Jan 29 16:32:21 Mike-Rosss-iMac.local locationd[251]: Location icon should now be in state ‘Inactive’
Jan 29 16:32:22 Mike-Rosss-iMac.local Console[781]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
Jan 29 16:32:24 Mike-Rosss-iMac.local WindowServer[184]: disable_update_timeout: UI updates were forcibly disabled by application “Console” for over 1.00 seconds. Server has re-enabled them.
Jan 29 16:32:24 Mike-Rosss-iMac.local WindowServer[184]: common_reenable_update: UI updates were finally reenabled by application “Console” after 1.13 seconds (server forcibly re-enabled them after 1.00 seconds)
Jan 29 16:32:37 Mike-Rosss-iMac com.apple.xpc.launchd[1] (ZBrush.226948[786]): Service exited with abnormal code: 1
