Sorry for noob question but is this waves is normal for rigging with zSpheres?
Posing should be done on a lower subdivision level if you are using a ZSphere rig. Then you won’t get the waviness.
You might want to check out these videos on rigging.
Part 1: ZBrush Rigging with a Single Subtool
[Part 2: ZBrush Rigging with Transpose Master
](https://www.youtube.com/watch?v=li4Q4XlkPlE)Part 3: Rigging Multiple Poses
Yep, i I watched these videos. But i worked on lowest subdiv level (this cylinder mesh contain only one subdiv level). Maybe its happens cose mesh contains too many active points (cylinder in this two pictures contains ~1000 active points).
Also waves disappeared when i create more zspheres and rotate all “chain”.
