In the Brush menu under Sculptris Pro tab there is a button that says “Wants Sculptrispro”
What is this for?
hi @sculptzz, and welcome on ZBC.
Wants Sculptris pro switch is for when you create your own brush that need the sculptris pro mode enable to work, so if you save a brush with that option and load it at a time, if the sculptris pro mode is not On at that moment, it, gonna tell you, that the brush use the sculptris pro mode.
Hope it Helps!
Nicolas
