ZAirbrush is a ZPlugin/Application that intercepts messages from the Wacom driver in order to enable a few cool features on ZBrush, such as:
- Stylus Tracking: Got a regular grip pen and an airbrush for your wacom tablet? When you pick and use one or the other, ZB will remember the last brush you used with that pen and bring it back when you pick it up again.
Only have one pen? No problem: the same is true if you switch between the tip and the eraser.
Wheel control: This one is specific to the airbrush, as it enables you to use the finger wheel to control Draw Size, Z and RGB Intensity. As a bonus, you can use the button close to the wheel to cycle between these 3 modes.
Extended touch ring controls: Buttons and hotkeys for you to customize your Intuos Touch Ring in order to change the Draw Size, Z Intensity, Rgb Intensity and to cycle back and forth through your alpha and brush libraries.
I’m still finishing everything up, polishing some rough edges, and I really could use a few beta testers… so if you’re interested, please send me a private message and I’ll send you the files and the how-to’s.
