I recently got a new 24HD Cintiq; however the buttons, are sluggish in ZBrush, especially with the newer drivers. The oldest driver for it will work but then other issues pop up. I tried the same thing on different Cintiq and it had the same issue. I called Wacom but they said that it might be some Zbrush issue. The thing that makes it most noticeable is that if you use the buttons on it (like the option key) to rotate your model, then it may or may not work. It becomes a pain to work with your model. Has anyone had this problem or seen any fixes for this?
Setup:
Mac Pro
OS 10.7.4
