Hi everybody. Im beginner and that may be an easy question. Could You give ma an advice on how to get rid of that visible line between two subtools. Do I have to merge them and than use a dynamesh or is there a different method. Cheers
Hello @Astroteles_Evetrials
That seam is there because the two subtools are merely intersecting, not fused or welded together.
There are several ways to fuse geometry together in ZBrush.
You can use Dynamesh to fuse the subtools together if the all the geometry involved has been merged into a single subtool.
You can use Live Boolean to non-destructively create an entirely new fused tool in the Tool palette from the visible subtools.
