Viewport jump when undoing
HI there, i had this issue for a while now this doesn’t happen every time, at some point in the session if i undo or polyframe my viewport will jump way out after the first time it happens i then get it sporadically. If i undo immediately after first stroke it will surely jump again not after multiple strokes, its holly weird.
Im on mac newest version of zbrush using mouse, my perspective and camera are off no animation just sculpting.
Many thanks.
Mariusz
Hello @barayase,
I’d suspect an issue with the tool you are using being outsized or off center. Also possible is an issue with an input device like a tablet, and some sort of Zoom functionality. It’s impossible to say without much more information. Please either document the issue much more extensively here, with completely uncropped images of your interface, or if you are uncomfortable doing that, head over to Pixologic Support and start a conversation there.
Thank you!
Thank you for your help, ill try to get to the bottom of things, i use mostly a mouse for my sculpts, my wacom 5 has always been an issue always causing modifier key problems, it may be steermouse the software i use for my twenty button mouse, i never had a problem with it and i used for years. ill start uninstalling things and will let you know how it goes.
Mariusz
I have the same issue for long time. I tested in different big and small sizes . doesnt help.
it pops out when its micro zoomed and camera has angle. not in 90 degree .
it happens pushing the polyframe and undo.
