VarSave & VarLoad
I’m trying to save some variable data to a seperate file so the person using my script can pick up where they last left off before closing ZBrush.
I have 3 variables to save, they contain the individual R, G and B channels.
I define my variables at the beginning of the script. And later in the script, this is how the value get stored…
[VarSet, colorStoreR, Color:R]
This sets the variable, colorStoreR, to the value of the current R color channel. Next, saving the channel to a file…
[VarSave,colorStoreR,session]
Now I have the correct color information stored in my variable, and I am assuming that those values are also being stored into a file called session.zvr
Next I got about loading the stored values. When you click the load button this is the order of execution.
[VarLoad,colorStoreR]
I assumed that this line would set the variable to the previously saved value. And then finally…
ISet,Color:R,colorStoreR
Which sets the Red color channel to the current value of the ColorStoreR varialble…
PROMBLEM
The script does create a session.zvr file but it’s either not saving properly or its not reloading properly. All the variables are stuck in their declared 0,0,0 states.
Well I got it finally, I needed a seperate .zvr for each individual color channel.
The other way you can do it is to declare a list variable:
[VarDef, myColors(3),0] //declares a list variable with 3 items, initialized to 0
Then assign the colors to it (the index starts at zero):
[VarSet, myColors(0), Color:R]
[VarSet, myColors(1), Color:G]
[VarSet, myColors(2), Color:B]
To save you simply save the variable thus:
[VarSave, myColors, settings.zvr]
and load in the same way.
Oooh thats elegant. Thanks for the tip.
