Newbie here… I’m trying to create a simple t-shirt from a model and get a UV map for it.
I created a base t-shirt by masking the model and extracting. I then went to UV Master and clicked “Work on Clone”. Next I hit “Unwrap” and then “Flatten”. Didn’t look good. I played around a bit and finally created the seams by polygroup. This worked pretty well except that it unwraps both the inside and the outside of the t-shirt… is that normal? Is it possible to select only the surface or is it best to stick with the inside and outside being unwrapped?
Edit: Thought I’d put a couple of images in to illustrate
