UV Master Check Seams not showing properly
I checked the forums and google searched this, but I’m not finding anything concerning a weird pattern I’m getting on “Check Seams” from UV Master. I’m a bit newer to Zbrush, but I’m pretty sure I’m doing everything correctly. I keep getting these weird patterns when trying to check the seams (on a cloned mesh), yet the islands are properly separated when viewing them “Flattened”. I only used this once in R6 (while learning) and I don’t recall getting this. Any suggestions would be helpful.
I’m using the Mac (Yosemite) R7 64bit version. It’s not a huge issue since it does separate the islands properly, and I’m going to tweak them in another app, but I was trying to keep as much of my workflow within Zbrush. Thanks.
did you try to update to P2 and see if the problem was gone?
Hi elemmanuel, I just saw the update from your post, thanks, I’ll give that a try.
This problem has been identified and it will be fixed in the next patch for ZBrush 4R7.
Thanks for the update Totyo!
