uv maps from outside z brush
I have been using an old copy of Zbrush (4r6) my college has installed in the lab to mess around with making pleasing textures and normal maps, but I have hit a snag. the model i made was made at home ( I’m poor) on blender 3D as a result I have a nice amount of control over getting the uv’s how I like them, when i put the model in zbrush (obj format) and sculpt I have no problems, however the problems occur when I create a normal map, every time I’m met with this.
https://www.dropbox.com/s/z38fsntkscsujgk/TORID.jpg?dl=0
the triangles appear all over the image and overlap things,
here is another image from blender to show more of how the image should look.
https://www.dropbox.com/s/r1rkfpan0612m4d/torid%20normal.png?dl=0
this has happened on other models I tried with too, any ideas how to stop this happening?
EDIT: solved the problem by triangulating faces and setting the objects to obj groups and ob objects.
