Hi Guys,
I understand that you have to press “New Txtr” Under Texture Map before you send your object from Zbrush to Keyshot. Otherwise when you applied UV Coordinates as mapping in Keyshot, it just doesn’t work.
The question is, what if you have many objects that you want to send to Keyshot ? Do you have better suggestion? Or I have to keep clicking the button as many times as the objects?
Thank you
