I have an original model of around 10 million polygon model from a scan (A).
I then performed extensive cleanup in Zbrush using sculpting & dynamesh.
I have then re-meshed the dyanmeshed version using Zremesher & subdivided (to 6million polygons) (B).
I would like to project a lot of the very fine detail from the original scan model A onto the model B. However model A has a lot of bad areas that I don’t want to project onto the cleaned up version.
My options it seems:
it seems like I can use the Zproject brush & manually go & draw in the details from A to B. It is a slow process however & I feel like the detail doesn’t transfer over well (I’ll post a video)
ideally I’d ‘Project All’ from A to B but somehow prevent the unwanted areas from projecting . I tried masking the areas of model A I didn’t want projected, but this didn’t seem to prevent these regions from projecting. I know I can mask model B for areas I want to ‘protect’, but it’s hard to know which areas on B I should protect without seeing model A?
Are there any other tips for using masking to prevent projection of the undesired areas?
The video shows the areas that I do not want to project.
