Using Custom Menus in other UI Layouts as well
Hi all,
I was wondering if there’s a way to use a created custom menu that I want to have available for multiple
different custom layouts.
Now when I change user layouts I also lose the custom menu that I set up with a specific User Layout.
But I would like to have those user menus, now matter what Layout I’m currently using.
(I enclosed some screenshots… to visualize what I mean).
Is that possible without to have to rebuild that specific menu again and again in another Custom Layout? I hope you understand what I mean with that…
The aim is to be as effitient as possible.
Any help is highly welcome!
Unfortunately it’s not possible to copy a custom menu from one UI layout to another. You have to rebuild the menu every time. :frowning:
(A while ago I tried hard to use zscript to do what you want but I couldn’t get it to work!)
Hi Marcus
Thanks for your reply.
Good to know.
Ok, that’s a pity that this needs to be set up manually.
So, ZBrush has some space to evolve:)
regards, Fabio
