hello my question using this brush, curve tube snap, is: how can I change the shape of the mesh.
Because I need to use other different shapes, to the tube that already comes by default. ?
i attach a picture too.
thaks a lot for any answer !
Hello @untalmau ,
You have many options.
You could use the Curve Alpha brush to create a shape along a curve with a 2D alpha, the Extrude Profile brush to extrude a flattened piece of 2D geometry along the curve, or create an IMM brush as usual from geometry that can be welded along a curve if Curve Mode is enabled.
perfect … i am trying to find the curve alpha but i can NOT found yet …i will still searching
thanks for all help …
really apreciate so much
If you are not using the current version of the program please upgrade.
sorry my iMac only supports 2020 …i will upgrade son
thansknad bless
