Urgent! Bridge license dont work after ugrading Windows from Premium to Pro
Sent this to support but as I dont know how long the time for a replay from then will take I hope there is someone here that can help.
I worked as a nut to get my computer upgraded with more memory so that I could do some heavy work this weekend. Had to upgrade from Windows 7 Premium to Windows 7 Pro in order to access all 32Gb.
Now that I start to work the zBrush Keyshot bridge complains about corrupt licence end possible change of computer ID.
I tried to generate a new license file but when I click the render button I dont get to the screen in witch to load my license file.
Only get the message about corrupt license.
Tried to deactivate the license but still get the same message.
How do I get the bridge license to work again?
Would be very very graetful for help with this.
Managed to fix it.
License handling info seems out of date.
If I pressed reset in the zPlugin deactivation manager I was warned about ALL licenses would be reset and that I should not do that unless asked to by Pixologic.
But as the Deactivation button text was Deactivate Plugin and The entry that I previously disabled was named zBrush bridge I took the chance that this manager ONLY handles any plugin license.
And it worked.
Next time i used the bridge i could feed it the new license file and now it’s up and running again.
Wow just did the exact same thing you did. Your solution worked for me also. Thanks for the help
