Updating Materials in Zbrush and Update in Keyshot Pro
Hello!
I was wondering if anyone came across this problem that I have. When I update a material in ZBrush and than render it in Keyshot it does not update? I fillobject the color and save the tool but it keeps the original material. Is there a setting that I am missing?
Thanks for your help in advanced.
P.S. I was going to post this question in the Keyshot forum but I could not register. It kept timing out.
From I remember the ability of keyshot to keep the keyshot material even you export again is a feature. Keyshot suppose that you will substitute the materials in keyshot by native keyshot ones and you will want to keep them when doing updates. But it will send any modification of the polypaint and geometry, only the material is dismissed.
You can send again the entire object if you rename it or if you save, close the project, and load it again as the connection with zbrush will be lost.
