Undo Commando question
(I hope this is the right forum for this question…)
Hello,
I would like to rebind “Undo/ Redo”, but I noticed that I can’t simply ctrl+alt click on each button and rebind, because every time I take an action, the button “changes”. So, I sculpt on my model. It says “Edit->Tool-> Undo 30”
for example. I rebind it (ctrl+alt+click).
I try the shortcut, and it works, but the button is now labled “Undo 29” and the valid shortcut is no longer working. And I don’t think I can apply the same shortcut to every step of “Undo” because it can only be assigned to one button at a time.
Is it impossible to re-assign the shortcut for redo / undo?
Or am I missing anything obvious?
EDIT:
I found a thread with a smiliar issue here…
http://pixolator.com/showthread.php…t=undo+shortcut
Sadly though, when I added those lines to my startup hotkeys (with my prefered shortcut instead) it didn’t work.
Help, please! ;_;
Thank you in advance!
Your link doesn’t work for me so I’m not sure which method you are trying. Did you edit the StartupHotkeys.txt something like this:
[EDIT:UNDO,634]
[EDIT:TOOL:UNDO,634]
[EDIT:REDO,890]
[EDIT:TOOL:REDO,890]
The method is described here:
http://www.zbrushcentral.com/showthread.php?t=50147
If this doesn’t work for you then I don’t have any other suggestions I’m afraid.
Thank you for your quick reply.
If the link was working, it would lead to a thread in which you suggested the same. I tried it again, but sadly to no avail.
But thank you anyway.
