TOO often this thing pops out during rest time and mush worse is ZB do not save ANYTHING!! Please , fix at least autosaving a tool!!!
Hello @anxiousdreamer ,
If you are experiencing technical issues with ZBrush, please contact ZBrush Support. Technical Support for ZBrush cannot be conducted over the public forums. If this is a general issue you are experiencing when working with any file then this is probably due to an issue in your installation environment. If it is only happening in a certain file, then the issue is likely to be related to problems with the content in the file. Both of these possibilities will require Support assistance to identify.
I’m going to close this thread just so there is no further expectation of assistance here and that you don’t feel you’re being ignored.
Thank you!
