Hello,
Is there a way to Mirror a subtool without losing any details?
im aware that to mirror a model with subdivision you have to freeze subdivision level first,
however when i uncheck the freeze subdiv button the mesh vertices were all messed up.
so then another way is using mirror and weld features, with this i was able to mirror the subtool and retain its subdivision, but again the details is not as accurate as the original subtool, it looks like it has been smoothened.
any idea how to mirror a subtool while retaining the details as accurate as posible?
the right side is the original model and the model on the left side was mirrored after freeze subdivision level pressed
the second attempt is quite succesful but as you can see the left models details is not accurate
THANK YOU!!
