Unable to import 14m mesh(but can subdivide and save to same/higher polygon count)
Hi I’m getting an error where zbrush is unable to import a highres mesh of about 14milion polygons, but I can easily work with this much and more(per tool) within zbrush itself. I have 32gb ram, Ive actually formatted and updated my machine’s hardware(brand new mobo cpu and ram) since originally running into this issue so I know it should not some sort of install or hardware issue.
Am I not configuring something correctly? I think im even able to export this many polygons from zbrush, but importing always fails, even if I export the mesh from zbrush and try to reimport it!
Using 4r8 p2 on windows 10 with 32gb ram
I think ZBrush has a problem importing OBJs that are over about 2GB. I started working on a plugin to cope with this by splitting the OBJ. It’s pretty rough and won’t handle UVs or polygroups but you’re welcome to try it if you want. I’ll PM you a link.
