UI Scaling issue [Solved]
Hi!
I have an issue with the zbrush UI being scaled up quite a bit after a re-install of a floating license.
I am not using any scaling via windows or any other method that I am aware of.
I’ve tried restoring zbrush to default settings and using other .cfg files. Nothing seems to fix it.
Here are two screenshots of my zbrush UI, the first one if from my home machine. The second one is on my work machine. You can see the UI is being scaled up considerably.
How do I fix this!? Thanks
Found the culprit.
Somehow the ui Buttons Size slider under Preferences > Interface > UI got changed. I swear I didn’t touch it. very odd…
Anyway, sliding this back down to 38 fixed my issue
I’m glad you solved it, Eric. The ZBrush button size is an oddity as it is not stored with the usual config file and is saved automatically. I’ve a feeling that the default position has something to do with monitor resolution, though I’ve never investigated; I presume the value must be stored in one of the other config files that ZBrush has scattered around.
